'64 Gas door emblem fix
carrollm
HBG,PA20minutes from Carlisle!
64 327/300 4sp.CP., 66 CP 355/4sp
Has anyone replaced their gas door emblem on a 64? I see they are available for about 36.00, but it looks like you have to drill rivets to get it apart??:confused
Any info welcome:w
64 Mike
gas door emblem
I replaced the gas door emblem on my 65. The instructions come with the replacement parts. You will have to drill the rivet heads to remove the back plate. Then you will drill and tap so that you can re-assemble using screws. If you are looking for an NCRS restoration you will need to make the screw heads look like rivets. The process is almost the same as replacing the aluminum panel in the glove box door.
Hope this helps!
Ray
gas door
I also replaced my 65 but they didnt have just the emblem so I had to order the whole deal
Its a lot lighter than the original
good luck
