brumbach
What are the procedures to replace the battery gauge on a 65 vette? Is it possible to restrict the work at the gauge or do I have to pull the entire cluster? Thanks -- Bill
From personal experience, although it might be physically possible to get the pod out, by removing some of the items at the lower dash area, it will be much more difficult to re-install the pod without damaging the gauges, when it becomes time to put it all back in place.
Like everything else we dis-assemble, it's usually much easier to get things apart, then to get them back together correctly. :ugh
Good luck with your choices
Stepinwolf
