65 coupe frame
Wilkinshc
New Mexico
1965 Coupe
I have a 65 coupe frame. Has VBP upper and lower aarms, composite spring, steeriod rack & pinion steering, qa1 double adj front shocks, front ssbc alum. calipers, Stainless steel brake lines (manual single), front slotted rotors, c-3 spindles and hubs, frame has been sandblasted and powder coated semi gloss black, stock tranny crossmember has been removed and has a bowtie overdrive crossmember but I still have the stock crossmember and it can be welded back in if you prefer. Rear differential is out and apart but is all there. Has big block caps, 323 gears, all stock. Was planning on going with Tom's Differentail setup but I don't want to wait till their available so if I can sell this I will be going with a tube chasis and fab 9 rear. 7000 located in abq nm . There is pics on my homepage link but can email more detailed pic you want.
Work number is 505-896-5566
home is 505-891-9545
Chuck
