Francis Ford
- Joined
- Oct 16, 2009
- Messages
- 6
- Location
- orchard park NY
- Corvette
- 1960&1966 coupe trophy blue high option s
On ocasion (recently after local parade duty) the engine temp crept up to 220* on gauge,turned on the heater to relieve more heat from eng.note :radiator did not boil over.. .After we got home and parked the car ,we saw a qt.or so of ATF on the ground,prob came up thru the overflow vent.(alum.66 P.G. orig.and totally rebuilt .and not driven till now.) ....there seems to be a corelation between high eng.temp/overflow atf loss..tranny only looses atf at these times.
Ques.
1) atf expansion ???
2) is it possible to connect tran.cooler lines incorrectly,(inlet/outlet reversed/)
3) tran.cooler partialy blocked/or larger cooler needed?
4) OTHER...???? would be appreciated :eyerole
Francis
Ques.
Francis
