67 coupe door hinge stressed
jims427400
Temperance Michigan
67 427 tripower,68 427 tripower,04 Z16, 62 340hp
My coupes drivers side door appears to have been opened too far at some point and looks like the aluminum rivets on outside of door are bent,and hinge appears loose on inside of door even though all bolts are tight.Is this a hard fix?
Those rivets hold the steel hinge reinforcement box to the door inner panel; if you can't re-set or replace the rivets (door needs to be off the car for that), you can replace them with carriage bolts, nuts and washers.
