67 headlight problem
jims427400
Temperance Michigan
67 427 tripower,68 427 tripower,04 Z16, 62 340hp
Last night I went to raise the lights, right side went up just fine. The left side would open approx. 80% then begin to close. The head light indicating light on the dash never went out. At 80% open I got out and the headlight would rock up and down about 2 inches. Any ideas ??
John Mcgraw
Austin Tx
1960 Roman red, 1959 resto-rod, 1965 resto-rod
Drive gear is worn out, it is time for a rebuild of those motors!
It is really a pretty simple job to rebuild them.
There is nothing that would cause one motor to reverse and not the other. Both motors are driven by the same circut. The switches and indicator lights are nothing but advisory in nature, and have nothing to do with the operation. They are simply there to warn you that you have your headlights turned on with the lights in the down position.
Regards, John McGraw
jims427400
Temperance Michigan
Thanks John,
Can you tell me if you can, if theres a rebuild kit that you'd recommend and what vendor. I remember seeing somewhere on this forum a step by step for this rebuild. Anyone steer me in the right direction ?
Thanks.. Jim
John Mcgraw
Austin Tx
I do not know of a kit, per se, but most of the vendors carry the individual parts for the headlight motors. The gear is pretty much a drop-in installation, but maybe someone will post a link to the procedure.
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
I have taken my motors out and just simply reversed (rotated 180*) the gear and greased them. Both of my midyears worked perfect after that with no parts purchase involved. The gear wears on just one side. A friend that showed me how to do this did both motors on my '65 in less than an hour while we were killing time at a show.
Tom Bryant
Administrator
Yeah, That's what I meant. Great article.
jims427400
Temperance Michigan
Great resourse.. thanks for the article..
Looks easy enough, best part is not needing to order new parts.
