68BigBlock
;help Recently completed engine overhaul and engine bay "revamp" from firewall to bumpers -- installed engine back in car and tweaking everything to get car back on road.
Having problems with headlights not operating correctly. Have read all links and printed/ reviewed most vacuum line articles and "how to" material showing hose routing, filter and check valve use/ importance, etc. etc. Believe I have all vacuum lines routed properly -- again, believe them to be. Also installed new vacuum tank while engine was out -- old one would not hold vacuum.
Here's my issue: Headlights are in the "open" position and nothing I have been able to do thus far will move them down using vacuum system. Prior to vacuum tank replacement, I had bypassed the vacuum tank completely and everything worked properly. Can do that again, but prefer to make use of tank as system originally designed.
1. Where do I start-- what do I need to look for?
2. What is the "normal" position for the headlights on the '68 model--- some of the material I have read indicate the '68 may be different than other C3 later models.
Thanks in advance.....:confused
