68 tripower intake question..
jims427400
Temperance Michigan
67 427 tripower,68 427 tripower,04 Z16, 62 340hp
I've found a numbers matching 68 tripower 400hp.The previous owner is selling it with original dated carbs but w/a 435 hp intake.
Will a 435 hp intake work on a 400hp car??
thanks..Jim
I believe the 400hp engine should have oval-port heads, the 435hp rectangular-port heads, they will not interchange
thanks..Jim
Yes, it will, but obviously not at its optimum due to the slight "step" at the port interface (large rectangular ports on the intake, slightly smaller more oval-shaped ports on the heads).
I have a set of 1968 840 square port heads that will work with that set up if you need them. 330-770-2517 Dennis Vugrinovich.
