I'm having a ton of trouble leveling my doors. Both passenger and driver side doors. The gap between the door and the fenders at the bottom is almost non existent. The top of both doors has a pretty big gap. I have the door shims, and tried different combos on the passenger side, and haven't used any on the drivers side yet. If anyone knows maybe the standard number of shims you have to use on the top and bottom, and maybe I can work from there. This is a concern because it seems the bottom of the door is chipping the fiberglass on the fenders. Please help.
ad
Also if anyone knows... I have been trying to install the drivers side mirror. There are two holes on the outside of the door, and 1 hole on the inside.. How am I suppose to bolt the mirror bracket on? It boggles my mind. Thanks
adAlso if anyone knows... I have been trying to install the drivers side mirror. There are two holes on the outside of the door, and 1 hole on the inside.. How am I suppose to bolt the mirror bracket on? It boggles my mind. Thanks
