AnytownUSA
I have a clutch-ish issue. I just found how to get the ECU from above the reservoir so I have not checked the fluid level yet. But the more I read, the more I think my trouble is not the same as previously discussed. Past posts have been on not having enough pedal or the clutch not disengaging all the way. My clutch performs as usual so I don’t think my fluid is the culprit. My problem comes when I press the pedal all the way in. Everything is fine until I have about 1.0 to 1.5 inches of travel left, after that it sounds like a machine gun going off under my hood. Hot, cold, wet, dry, sitting, rolling, all the same. It’s a 94, 73k miles. Any help would be appreciated - I don’t even know enough to pose an adequate question!
As a side note, one thing I love about this community is that most every thread gets a response. I have recently posted a couple of questions on a Jeep page concerning trouble codes and radio wiring of my Cherokee. Both posts have been up about a week with several views and no help offered – not even an encouraging bump. I really do appreciate the environment here on the CAC, consequently I always help if I can – which isn’t all that often but I make an effort.
