L
lostintime53
It was the first beautiful day this month and I decide to drive the 71 SB coupe to work. I backed it out of the garage and let it warm up for a bit. I noticed "nickel coin" size wet spots in a neat little row from the garage to the front of the car. One touch and it smelled like gasoline. I opened the hood while the car was running to check for the source of the leak. It appears that the gas was coming from the top of the fuel pump housing near where the hoses attach. The “S hoses” (Doc Rebuild) were replaced last year, are like new, and the clamps are secure. Gas seemed to be coming form a little hole in the housing itself. After sitting five months, my car is deadlined for a fuel pump leak.
Questions:
What is the probable source of the fuel leak?
What is the trick to replace the pump without the pump rod sliding out of the block?
Does a seal go between the pump and the block (I have had an oil leak around the pump housing for the last year)? We used black RTV for a seal (bad idea) last time we removed the pump.
Can engine oil blow around the fuel pump housing if the seal is poor?
Thanks in advance,
Rick in Tennessee
Questions:
Thanks in advance,
Rick in Tennessee
