71 to 73 L48
  • Thread starter Thread starter Augustus
A
Augustus
Okay I can't find the post anywhere, and it was along the lines of differences if any against the base motors from this time period.
As far as intenals all seem the same... Compressio, cam specs, induction... but HP ranges from 270 to 190? Is this primarily due to the Gross to Net measurement. I can't believe such a drastic drop on ratins. Even the 454 was at 270Hp in 72 and 73
So the massive drop occurred in 72...
My question is performance of the L48 from span 1971 to 1974 the same?
IMHO I belive yes... Maybe someone has greater insight, and I can learn a bit more. LOL
Let the games begin?
You are correct in that the '71 was rated at Gross HP while the '73 was rated at Net HP. Both engines were basicly the standard sedan engine but with a 4-barrel. Main difference would be that, more than likely, the '71 would have a higher compression as the '73 was designed to run on the lower octaine unleaded that was coming in a couple of years. Otherwise they were basicly the same.
tom...
Thanks Tom73
That is an awesome site... A plethora of info for 73 Owners..
Those vintage artcles are great also..
Nicely done.
So main difference was CR... So it must have been 9.0 or highier...
Not quite. THe L48 had several notable changes from 69 to 80. CR DID in fact drop from 9 to 8.5 in 71. A number of heads were used over the years though the smaller valve size was used in all of them. Cat and lack of dual exhaust of course in '75. Ignition maps changed almost every year.
Almost entirely due to change to SAE Net.
Believe it. The SAE Net ratings are relatively accurate and rigorous. The previous Gross ratings were often grossly distorted to the delight of marketeers.
Same engine, different head castings, different ignition maps and different carb calibrations and different takes on minor emissions equip essentially.
I think it's more accurate to say the L48 was an 'optional' sedan engine. There were more changes than 'just a carb' that included exh manifold, water pump, ignition, carb & carb calibrations, air cleaner, intake manifold, dual exhaust w/ dual mufflers...
Go back further to '70, for higher CR, the '71 had the same CR as later years. The 71 heads 'may' have had hardened valve seats. I think we can be relatively certain that hardened valve seats were standard by '73.
Nicely done.
See above... the big differences were a different head casting and different ign maps, different carb calibrations perhaps...
I don't see a website reference - can you re-post it?
The hardened valve seats were introduced in '73. '72 and earlier did not have them.
www.1973-corvette.com
tom...
Thanks guys..
It's good to know the L48 from 71 to 74 wasn't just a plain jane 350 but motor that is distinct - manifold/carb calibration/ignition mapping/exhaust manifold/air cleaner differences which do improve an engines efficiency..
Those ratings did have a big impact on HP Gross vs SAE could be a debate in itself. LOL
Sort of makes me proud to have an original matching number L48 car..:)
Similar threads
