K
KevinBelcher
Hi all
I'm having an electrical problem with my 71 and the battery keeps getting drained. Story is as follows:
I purchased the 71 454 convertible in August of 03. After a year of prep for the Woodward Cruise, I tried to start my car the morning of the cruise and only got a click... Purchased a new battery becase the other one was several years old already. Still Click... pulled the ground cables. Clean and filed them. Still Click...
After I say a few words of disappointment (if you can emagine), I put my stuff in the 03 and went to the cruise. But to this day I still can't get the issue resolved.
The car starts with a jump or a charged battery overnight.
While the car is running, my multimeter shows the battery is getting 14.25 volts of charge. Seems the alternator is working as it should.
The only item that runs while the car is sitting is the clock. I did a batery load test and find that with the clock running, it draws 15 mA. I found this to be odd but though that was the issue. I left the fuse out for the clock and the draw is .80 mA. Seems to be in line.
Left car sit for 24 hours and tried to start it. Click...
I next pulled each fuse 1 at a time and checked. Still draws .80 mA after each and all fuses are out.
Left it for 24 hours and it started fine.
Waited another 24 hours (just becase I was busy) and tried to start. Got my favorite tune Click...
Any ideas? I'm lost from here. Starter?
Kevin
Kevin
