69ttop502
1. Tach is a 5300 rpm redline. Outer metal bezel is great, blue plastic inner bezel is fine except for one mounting ear broken. Gauge works when spun with a drill. Face and needle are perfect. This part is original. $75.00
2. Speedo is in similar condition to tach with one mounting hole in inner blue plastic bezel broken. Needle and face are great. Trip odometer resets when tried. Outer bezel is great. This part is original. $ 75.00
3. Center gauges are in great looking shape. All work except the clock. All the fittings and oil pressure 90 degree fitting are there. Metal tray is good as well as top. Clear plastic is good and should polish up nice. All the little foam anti rattle strips are there as well as the head lamp and door ajar housing and lens. Clock knob is there as well. These are original gauges. $125.00
Will separate center gauges in a couple of days if nobody wants all for 25.00 a piece.
