72 windshield frame
bobfil
roch.ny
1972 convertible
I have a 72 corvette with a windshield frame that is rusted through near passenger top corner.Would also like to replace body channels on both sides, car has mild steel strips over rusted body channels screwed and bolted on,frame is restored but original owner over looked the channels.My question is are the steel strips strong enough, and should I just weld patch on winshield frame or go with whole good used windshield frame with pillar post and body channels? Any help appreciated Bob.
Artsvette73
New Jersey
1973 Silver coupe, 1977 L48
If you could post some pictures it would help. I can't help with the winshield frame as mine was good. What does the #2 and 3 body mounts look like? Two is behind the kick panel 3 is in front of the rear wheel you will see a plate with 4 screws. I ask about the body mount because it ties in with the rocker channels. This will tell you a whole lot more about the condition of the bird cage and what you will have to repair.
T
tonyvdb
I had rusty windshield frames and repaired them by welding in new steel plates. I think they came out really good. before and after attached.
