74 rear deck drain ??
CQRT
Scottsdale, AZ
2003 50th Anniversary coupe
Motorcity USA
1973 L-48 Coupe
i have them in my 73...
if you look under the wheel well...rear...you will see where they have a hole for this to connect from the deck grills to the drain outlet....mine had debris in them but they were in good shape so i reinstalled them.
Falls Church, Va
1972 Coupe ZZ4 / 4 Speed
vettedude73 is correct.
Also from inside the car if you reach back and feel around near the vents you will feel the rubber tubes. The run horizontally.
Mine are all torn up, and I am getting ready to replace them, as they cause water to leak into the car.
-Gooney0
CQRT
Scottsdale, AZ
thanks--
thanks for the advice-- took the grills out to clean and couldn't see/feel holes-- maybe they were covered somehow when car was re-painted before I bought it . . . sure is a pain to take the grills out every time I wash the car . . .
as an aside, has anyone chromed both the rear deck grills and cowl induction grill?? I understood that some "pot metals" wouldn't take chrome plating well - - and guesses on cost ??
thanks again-
CQRT
AZ
red70vette
Cortlandt Manor,NY
1970 red cpe 350/300
I have seen these grills chromed and have seen them offered for sale on Ebay and at swap meets. So they can be chromed if that is the look you want.
Check out the ends of the plenium up under the rear deck. You should find these drains extending through the carpet to the wheel wells. If your rear plrnium is holding the water they are either plugged with debris or someone decided to glass them over. They were there when the car was built.
