speedo swap and vehicle speed sensor
recently made the speedo swap, sort of. Corvette Clocks by Roger (Tennessee) took my 81 , 85mph and converted to a 165mph for less than the 140mph speedo would have cost from one of the catelogues such as Midland, Corvette Center. It looks like new and it still contains the same hook-up on the rear and whatever's inside to activate the speed sensor.
You can buy from the catelogues tiny, plastic gears to swap into the transmission if the speedometer is off. From what I've read here on another thread, there is a different speed sensor for the manual than that for the automatic. The only reason I mention this , is there must be another reason for the speed sensor other than to facilitate "converter lock-up"...but I yet don't have a clue what it does for the ecm. Incidentially, the sensor itself is blue, mine is made by AC, and is located at the driver-side , front of center console. According to the
Assembly Manual, it connects individually, at the top of the ECM. It didn't appear to be that way on mine, so for the time being, I'm leaving it alone.
regards, Jim
