'78 show& go
SJLJ
Denver co
1995 Yellow LT1 Coupe
I'm gonna list a bunch of goodies on this car I'm looking at and would appreciate any comments about how the pieces would appear to fit together and maybe what it would all be worth.
1978 New paint, brand new interior. 70000 original miles
MOTOR by Procell Brothers
The block is a seasoned chevy 350 motor is balanced and blueprinted with high quality parts.It is a full roller motor with crane roller cam,pro mag roller rockers and chromemoly pushrods.Pistons are 10.5.Dart pro 1 aluminum heads and stud girdle.Aluminum high flow water pump,new distrbutor with 50000 volt ignition coil,140 amp alternator,new 3 core radiator,dual electric fans, car does not come close to overheating.New stock exhaust manifolds and ported.
EDLEBROCK pro flow fuel injection system
TRANSMISSON by TCI new turbo 350 streetfighter it it has a new 2500 stall converter,flex plate,and fined alum.pan.
REAR END all new with 3.70 gears and heavy duty rear cover.The half shafts are new with hvy duty u joints.The trailing arms are completely rebuilt all new parts and poly bushings.
BRAKES new stainless sleeved calipers,new lines,and stainless braided hoses
SUSPENSION from Vette Brakes First the rear crossmember cushions, replaced along with the rear body mounts a big job.Then the rear dual mount monospring was added, this is lighter and stronger, and ride height, and spring rate can be adjusted.IT has heavy duty rear strut rods.Front also has a monospring it to can be adjusted, and no more heavy coil springs.Also has new hvy duty tie rod sleeves and ball joints.It rides on bilstein shocks.The power steering is all new, control valve,cylinder,pump,hoses.
GAS TANK restored over $500 it has compression style fittings and the fuel lines are fullly braided.
WHEELS stock highly polished with chrome metal centre caps and new chrome lug nuts.
INTERIOR was sprayed with sound and heat deadening material, then lined with heat resistance material, the car does not get hot inside from the drive train.All new carpet-dash-door panels-sunvisors-switches light and wiper- added were pace car seats and new leather cushons-140 mph speedometer-auto meter mechanical temp, and oil gauge which has a custom braided line-new heater core and seals and new dash - console and gauges covered with carbon fibre.
EXTERIOR new 80 rear bumper and taillights-fixed headlights and lexon covers, one set clear and one set painted, new fiberglass high rise hood and front spoiler-new outer- inner window seals-all new weather stripping including t-tops, and the car does not leak new front windshield-All window trim-sills-rocker-mouldings are powder coated.
EXHAUST-custom duals with spin -tech mufflers and h-pipe this has a big block sound, it is awesome.Pipes are bent so transmission pan,starter,drive shaft can be removed with no problem.
PAINT by RICHEY COLLISION the car was done the proper way- stripped, then doors,all trim,front and rear glass and bumpers removed.There are no emblems or antenna, the t-top trim was taken off to add to the clean lines.The color is custom with gold and pearl.Out of 4 shows car has 3- 1st and 1-2nd place finishes two were back to back years 03&04 at the big corvette and chevy expo.
Hope the mods will let this go thru. The car looks awsome.
Thanks​
