4
4spd350
Need some help !! My first problem was that my drivers headlamp was not going up. Found it to be a bad seal leaking at the boot on the actuator. So I ordered a rebuild kit for the actuators and installed them. Rebuilt them both. They work great, open strong and equally. Now the problem I am having is when I hit a good size bump in the road the headlamps open up then close emediately. Also when the lamps are in the off position, when I turn the car off the lamps open. I checked all my springs, the vacuum lines, everything seems to be in the right place. Can anyone give me some insight on this problem. Would be highly appreciated. Thanks. Maybe a check valve to keep them in the closed position until I turn the headlamp switch on??:crazy
