Vette/Berlina-coupe
- Joined
- Nov 18, 2002
- Messages
- 284
- Location
- southern california
- Corvette
- C3-coupe/MercedesBenz-540K replica! Racing-SB-V8!
-Yep, have '80-C3 brought in from out of state with bone-stock 350ci-sb (L48 with only 15k-miles), so am wondering if anyone has actual first-hand experience with what I am going to encounter trying to get the car approved in california, --owing that the Calif.'80-C3's had to have the 305ci-sb engine with the '81-type Rochester-Qjet having the integral computer-controlled/solenoid-valve when sold here here new! Discovered the Calif.-EPA ruling states any '74 or newer out-of-state purchased car must first undergo apparently stringent smog-testing, -even if the car is located in a smog-exempt region of california for example (once car is tested, then does not have to be further smogged if in a no-smog region of calif.)! So only have the car initially calif.-registered so far, but have not subjected the car even to an off/Smog-analyzer, --owing that the engine-configuration (they can tell engine-size by engine serial-number I guess) is apparently "black-listed"!!! Please advise of any knowledge about this gall-dang situation (any tricks around this will be appreciated, can E-mail me if preferred)...
~Bob vH
;help :duh
Jason- when I got the car initially documented with Calif.-DMV they said, --"you cannot SELL this car in Calif. until you successfully obtain Smog-certificate, and they are next going to closely inspect your car to make sure it is physically in compliance!" (--to which I replied: "I've no intention of selling the car..."); --but are you suggesting this is a possible loop-hole in the Smog-procedure, --that I should in fact go first to a simple corner Smog-station and just say that: "I am selling, --and so need to get it Smogged" (hoping that I find a Smog-shop that won't just say- "Oh sorry pal, these papers say you must go have the car Inspected first!")? --Right now the car has the Red/Calif.DMVtemporary-sticker in rear-window, Tennessee Lic.-plate on rear... ~Bob
Yoda- thanks for referal to the earlier discussion about this topic, but it still leaves me in a quandry about the '80-C3's unique small-engine requirement... ~Bob
~Bob vH
