S
Sarann
For about the last year I have had problems with the passenger door handle. It doesn't lock with the automatic door lock, so I have to walk around & lock that door with the key.
THEN on the weekend my husband was inside & when he closed the door he pulled the door handle off the door (a small white plastic part inside the handle broke but the remainder is intact).
Can I just order a new handle or does the entire door assembly need to be replaced?
I am in Canada, is there anywhere in Canada that you can suggest I call?
Thanks,
Thanks,
