Hey there I'm new here, and new to diag. probs on my vette. The story goes, got car road worthy and drove for 2 weeks. On the last drive, after I got back in , the batt was dead. I have batt leads to the back of the car (because of shaved handles). + goes to the pos batt, - goes to the bracket that holds the ecm behind the batt. My friend hooked his end (jump vehicle) up backwards, only for a quick spark. Then hooked up correctly. after letting batt take a charge, went to start and would fire but not run. If you give some throttle it will miss, backfire ect. Towed home. Now if I disconnect the 4 wire harness that goes from the dist to the car, it will run and sounds close to norm. My question is do I need a new ecm? If so does anyone have a used one f/s. Or could it be something else. Big thanks for any help Aaron
