Steve P
My street/strip cammed 350 is equiped with the stock Holley w/ electric choke. All polution crap is removed and several ports(all except EGR I think) in the carb are blocked with a short hose and bolt. It is over-reving at idle after completely warming up. I set the idle at around 800 while warm then go out for a short test drive. After getting on it a little, (not much over 3000 rpm) it gets stuck in something like fast idle mode(like 2000 rpm). I can turn the idle screw down to 800 again but when I restart it later the idle is so low it won't run. I have cleaned and lubricated the linkages and checked for a sticky acelerator pump. There is power to the choke when the key is on. Everything seems to be moving freely. I'm no carb genius. Seems like the prob is in the choke system or something to do with that rod that contlols the cam under the idle set screw. I'm in Canada but don't plan to run the car in winter so the choke is not really a major concern. Can it be easily removed from the equation.
Don't know if a power valve could cause this problem?
Any help welcome
Thx, Steve
Any help welcome
Thx, Steve
