81 Ring, Pinion & Speedo Gears
R
risctaker
When my '81 had only 3,000 miles on it, I yanked the factory rear end gears (I ordered the "G92 Perf rear") and installed a different set. The set I am selling, then "should be" the 3:07:1 set offered as the performance option that year. Speedo gear included to correct your speedometer. Gear set is "as new" except for the break-in milage indicated. $55.00 plus UPS ground. I uploaded a picture of the complete set. If it does not come through properly, let me know and I will e-mail it to you. Respond to Steve at risctaker@verizon.net.
R
risctaker
CORRECTION to '81 Gear Set
Thanks to Peter for doing the simple math and advising me that this gear set is actually a 2.72:1 NOT a 3.07, so if you're looking for better top end / gas mileage....
