Help! 81 vette crank no start.
Chris559
New member
Cen cal
New plugs, there is spark, theres gas, did compresion test on cylinder 1. Its between 90-120. Batteries are dying after a good 7 cranks. Im stuck at what it could be. Out a new module in. Help t.i.a
Welcome to CAC!!!
How old is your gas???
Is your carb getting gas???
Let's start there...
Sent from my XT1650 using Tapatalk
You may have to pump the gas pedal while you're trying to start it.
Anyone got a picture of how the distributor cap is suppose to be facing with #1 plug
I'll check when I get home this afternoon
Have you changed anything with the timing or distributor since you ran it last?
Tom
number 1 position on the distributor cap is just in front of the battery/tach terminals.
