Hi guys... wondered if the AC compressor 'should' come on when the system needs a recharge. When I put the AC slide control to AC then flip on the motor switch control, the alt gauge moves and the engine appears to 'kick down' as if the compressor engaged, but I do not see the plate on the compressor move/engage. Was wondering if the system has to have the freon, or whatever stuff is used, in it before the compressor engages.... my thinking is that the comp & AC system will 'protect' itself by not running if theres not stuff in it. anyone know for sure this is or is not the case? I'm going for a recharge soon but was trying to determine if the comp and AC system in general is functioning correctly so that when I DO take it for charge, they can simply recharge it and don't find the system not working for some other reason. Thanks much, Regards :>)
