My 82 seemed to be running great until I decided to fix the cruise. Now I cannot get it to run correctly. Only thing I did was disconnect hoses from the canister on the side that goes to the PVC and tank vent. Think I have everything hook back up correctly now.
My problem now is that once I try to drive the car acts like the fuel is being shut off at around 2K rpm (not every time though) and I have to pump the throttle to keep it running. Spits and sputters until I get enough fuel back to keep it running. I disconnected the vacuum line that went to the cruise and have it plugged off now (no change). Have checked the other vacuum lines and they seem to all be ok. Have plugged the vacuum line to the headlight and interior temp control (no change). Car seems to idle a little higher than normal now and also surges every once in awhile at idle.
Fuel filter was changed about two years ago and also have an 85 pump installed. Have not measured the fuel pressure but it was around 14psi the list time I checked. Will look into this once I find my pressure gauge. Have sprayed carb cleaner around the manifold lid and don't seem to have a leak.
Any thoughts on what else I should look at. I hate when you try to fix one thing and create another problem. Car ran great before I messed with the cruise, just came back from a 200 mile trip the weekend before.
