Question: '82 Sport Mirror R&R
rsisk
New member
Texas
1982 tutone blue coupe
Need info on removing mirrors to replace gasket. Can this be accessed without removing window glass?
...Can this be accessed without removing window glass?...
Kinda-sorta. You may have to take the lower window stops all the way down in order to get the door glass to lower further into the door. Nuts on the mirror mounting studs might be visible with the door glass out of the way. They are hard as the dickens to get to. A swivel head socket, various extensions, solicitation of the Almighty, and a ready supply of your FCB of choice will help.
:thumb
Favorite Corvette Beverage
Thanks for the update! I kinda was afraid that would be the answer. One thing you forgot to mention as for as needs, sounds like patience will be needed..
...One thing you forgot to mention as for as needs, sounds like patience will be needed...
That should be part of your solicitation to the Almighty. I always include a request for patience, good weather, luck, things to go like they're supposed to, and no surprises.
:thumb
