MoeJr
Hi. I jut got my 84 Coupe and need some guidance. Every once in a while when you start her up cold or after it has cooled down it starts and stalls then when u go to restart it it cranks likes it's flooded. It will then either start or I hafta get out and pull the injector harnesses off to let it "clear" out. I have not gone thru the car yet but am planning to. Some observations I have made since having it is that it doesn't really heat up alot. The other day after driving it in warmer weather it got up to 202 degrees for a brief second then fell back to high 180's to low 190's and stayed there. Today it was cool out and it was all I could do to get it to 160 which I believe is where the ECM goes into closed loop. I would like to hear any thoughts you fellow Vette owners have on this. It does not cause any major problems as when it does get warm it idles like a baby. Also notice the fan kicks on at about 180-185. I did order today a new stock chip for it and got the factory thermostat also. Any help is greatly appreciated. Thanks.
Moe
Moe
