84 electrical shutdown random left turn only
  • Thread starter Thread starter monte70
M
monte70
Need some hints as to what to test to fix this problem. When making a left turn( not fast) or (not granny turn) the car will shut down. Acts like you turned off the ignition switch. It will start back up when you do a key restart. This does not happen all the time. Sometimes can not make it fail. The vette is a 84 with a auto tranny. Gas tank can be full or near empty, It does not care.:confused
Do the lights and everything else shut off or just the fuel??? :w
Sounds like a wiring problem either in the ignition switch or wires that are contacted when the wheel is turned. Maybe a wire with some chaffed insulation is being grounded in certain conditions.
This doesn't sound like fun, good luck!
Steve :w
Everything shuts off on the dash. Never had it happen at night, do most of the driving during daylight hours.
Also when I replace the horn button I will check all the wiring inside.
