AussieCorvetteNut
Hi Guys,
Well I recently picked up a 1984 Manual Coupe, with the Doug Nash 4+3 combo.
Overdrive doesn't engage at all.
I have ordered a new overdrive relay, it has arrived and is ready for me to collect from the post office.
I am assuming that the Gage fuse in the fuse holder is OK as I have all instrument cluster operation, speedo etc. I ordered and installed a refurbished Instrument Cluster, but had to use parts from the reco unit and my unit, as when the Vette had a right hand drive conversion, the cluster got changed and the wiring harness plugs move from being plugged into the side of the unit, to being plugged into the rear of the unit...lot of soldering done there. :ugh
Last owner said he doesn't recall if the overdrive ever worked in the 11 years he had it...
My decision is to try and find out if the overdrive does actually work or not.
From there I can pull it out and rebuild both the gearbox and the overdrive (I have both rebuild kits) or junk the DNE and opt for an upgrade.
I don't really want to junk the DNE, as I am sort of thinking that my Blue two-tone 84 Coupe with the DNE is low production...cloth trim is also an issue, I can't figure out why the original owner ordered cloth trim.
I would prefer to fix what she came with and enjoy, be a caretaker. Parts are the issue for the DNE system, I cannot find simple parts such as the overdrive rocker switch on the console...rare as rocking horse poo.
Switches on the side of the gearbox also seem to be rare.
Has anyone changed the overdrive console switch for an 1985 selector with the overdrive button on top?
I also need to check the fluid levels in both the gearbox and OD unit.
Appreciate your thoughts.
Cheers
Tony
Cheers
Tony
