'84 Trim Tag location?
S
silver84
I found my RPO tag in the back storage box, but where is the tag that shows the car color, interior type & color, etc.? I have looked everywhere!
8
84c4
It will be on the bottom of the trim tag, listed in an area by itself.
Dave
S
silver84
Thanks Dave,
I do recall a number at the bottom of the tag, but when I looked at it, it made no sense relative to the color codes, etc.
Maybe I'm not reading it right.
Thanks!
T
thevettenet CA
silver84 said:
Thanks Dave,
Thanks!
On the trim tag, it's a paint code, not the RPO number. At least on the later model cars, it's coded BC/CC for base coat/clear coat.
S
silver84
Thank You! I'll check it out. Hopefully I can find the paint code identification guide on this website somewhere!
CorvetteArchives
Carbon County, PA
1984 Z51 Silver/Gray & as Much SS & CFibre we find
Hi
the paint code sould be 16 for bright silver metalic.
On our build sheet it says it.....but knowing GM not surprised if it isnt there!
We have the build sheet example and All the color codes at our website under "archives"
:w
S
silver84
Awesome website Christian & Sue! Thanks!
hotrodbob
SoCal
1989 Black coupe
Are all C4 trim tags in the same location?
bill81vette
Moderator
Troy,NY
1981 dark blue metallic
to the best of my knowledge ,yes they should all be in the same location.
hotrodbob
SoCal
1989 Black coupe
Thanks:cool!:
