85 Dies immediatly after starting
  • Thread starter Thread starter JayD
J
JayD
My 85 will start and then immediatly dies about 80% of the time, other times it starts normal. It does it warm or cold. If I push down the accelerator while starting the car will start, but only remain started until I take my foot of the accelerator.
To try to fix it I have: replaced the fuel filter, PCV valve and checked TPS voltages.
About a year ago: the plugs, wires, EGR valve and fuel injectors were all replaced.
Any ideas about what to try next?
Do you a SES light coming on when it is running?
Mine did that about every 5th time I started it .
It was flooding, I had the injectors professionally cleaned, and no problems since.
[I see you got new injectors last year]
Try disconecting the battery.check fuel pressure , check conectors on the ecm check for rust dirt check plug back at the fuel pump.:confused
