"85"stock cam numbers???????????
pennsylvania
stroked 85 blkrose coupe
gettin close to puttin my baby to sleep for the season so that
means i have alot of work to do by spring. i am building up the motor
and would like to know some of the stock #'s to use as the guidelines
for reference i have the usual stuff but need to know what the int &
ex lift and lsa are for the stock cam.
thanks all
chris
Duration @ 0.050 202/206
Lift with 1.5 R 403/415
Lobe Seperation 114.5
Vader,
You wouldn't happen to know the numbers on a stock '90 cam would you? Is it the same?
Hrtbeat1 said:
Vader,
CAM 90-91 L98 10111773 In/Exh Dur @ .050" 202'/207' Lift (w/1.5) .413"/.428" LobSep 114.5'
Not the same type of cam either, 90 is a roller, 85 is hyd. flat tappet
