C4ME
Where is the location to find the engine suffix code that details whether a car has aluminum heads? I am interested in a local 86 and the seller claims it has aluminum heads.
C4me
C4me
Precise numbers? No. But some coupes were equipped with 'em.C4ME said:... are there numbers of the coupes which were fitted with these Johnnys?
The number I'm refering to is the number stamped on front of the block right in front of the cylinder head. It is coded to tell you if the engine came with Aluminum heads or not.Moonunit 451 said:That block number ain't all that easy to see. It's on the top pass side back by where you mate up the tranny, about 11 o'clock.
the magnet is best as all GM small blocks went to a centerbolt head around 87, and without knowing the history (or numbers) of the car you can never be sure the engine is origionallarry bud said:You can tell just by looking at the bolt pattern on the valve covers on a stock motor. The cast iron has the bolts on the edges of the cover, the aluminum heads has the bolts right down the center of the cover.
If it's not stock, a magnet sounds good.![]()
The engine number will verify that the engine is or is not the original engine for that vehicle.bossvette said:the magnet is best as all GM small blocks went to a centerbolt head around 87, and without knowing the history (or numbers) of the car you can never be sure the engine is origional
