86 dash lights
mikevochis
CT
03 50th Convert, 91 & 94 coupes & 96 Collectors
My turn signal indicator bulb must of blown. Outside the car everything works, just the dash light is out. Has anyone fixed this before??? What am I in for, is it a big job??? Any help or advise would be great. Thanks
BigRed
Edmonton
1985 Bright Red Rocket
Minor, Pull your plastic cosmetic bezel off (I think its 5 or 6 screws) now you'll see the uglyness off your dash cluster.
There will be two plastic push knobies holding up a clear plastic thing that defines the shapes of your Signals and your Brights on light.
Pull out the knobies and you'll reveal the three bulbs (2 signals and one bright light one) Now simply replace the bulb(s) and put back together.
While your in there looking around this is where the 4 Halogen bulbs are that light up your LED dash cluster if you ever need the replace them. Underneath the 4 tin plates (Simply pull them off) are the bulbs.
S
Shadowing1985v
hehe, i had the same problem with my 85
all i did to fix it,, well at first i had no idea what was wrong, but then i was puttin gin my car cd player
and i founda inline fuse that was burned out i replaced it and it started to work again
try that
