87Z52
Hey all,
Last fall when I put the car to bed for the winter, the passenger window would not move. It had worked great up until that day when it did nothing. I decided to leave it until spring so here we are.
I pulled the door panel today and noticed that the interior lights dim ever so slighly (as normal) when the switch is moved and I can hear a "click" from inside the door. No movement of the regulator at all.
Now, this car has always puzzled me because I was always under the understanding that 87 was the first year for the new-style regulators (non-ribbon type). My driver's door appears to have the ribbon type because it is very slow (like my brother's 86 was) compared to the pass. side. Also, the mounting bolts on the bottom edge of the door indicate that it is indeed the older style regulator (two bolts, one toward each end of the door). The newer regulators (correct me if I'm wrong), have two bolts relatively close to each other toward the rear of the door (as is the case with my passenger door).
My car is a very early 87 (within the first 130 cars of the model year). Is it possible they were still using up old ribbon-style regulators for the driver's door? Anybody else run across this?
Anyway, back to the problem. What is the likely failure here? Motor? As long as I've got the door apart, I think I'll be replacing weatherstripping as well. Since I want to replace the weatherstripping on BOTH doors, I'll have the other door apart. As long as I'm inside the OTHER door, I was considering replacing that regulator with the newer-style unit. This little "fix" is snowballing as usual!!
Any ideas on fixing the passenger door? Any tips on replacing the old ribbon regulator in the driver door?
Thanks in advance!
Thanks in advance!
