87 steering wheel play
J
jmooney
HI guys, my 87 has about 2-3 inches of play in the steering wheel. With or without the engine running, the steering wheel moves without any input to the wheels(turning back and forth). I go under the hood and move the steering shaft by hand and it does not seem to be coming from the "rag" joint, it seems tight. Does this mean I need a new steering rack? Anybody have any ideas? Thanks Jack.
vigman
Motor head!!!!
Valencia, CA,USA
This is not good!
I would get the front of the car in the air...
get somebody in the car.. as you watch under the hood..etc
Check the coupling from the steering column to the input of the rack....
If that is tight ... start going back to the steering column.. there is a shaft ( with 2 U-joints in it) coupling the steering shaft with the input to the rack.
There is also a bearing at the base for the steering coulmn.
If these are OK... look under the Boots at the ends of the rack... Then the tie rod ends...
Do you get any clunks or other noises?
Suptin's fishy.....
and If it were my car I would NOT drive it until I knew what the problem was...
Vig!
J
jmooney
hey Vig, thanks for the information! I am going to check it out right now. As far as other
noises; no I don't have any. Your other statement rather scares me though, as I have been
driving it like this since I bought it in January. I really appreciate your help,thanks again.
Jack
J
jmooney
hello Vig, I checked the things you mentioned and guess what? I found the pinch bolt
loose at the steering rack. I feel so stupid! I never looked under the plastic cover over that
area of the steering shaft. I have not test drove it yet, but all the slop is now gone from the
steering wheel now. I can't tell you how much I appreciate your input!
This is my first Corvette and I am enjoying it so much. I always enjoy all the looks I get
wherever I go. It is nice to be in such great company with all you Corvette owners.
Jack
vigman
Motor head!!!!
Valencia, CA,USA
Jack
Your welcome.......
Welcome to the BEST......
CAC ROCKS:_rock :dance :upthumbs :upthumbs :booty :Twist :BOW :CAC ;worship
L
LarryK 87
So how difficult was it to get at the pinch bolt?
J
jmooney
Hello LarryK The pinch bolt was kind of hard to get to. I ended up using a long extension
to reach between the power steering fluid holding tank and the alternator. I could get a
socket and ratchet on it lower but then I had no room to turn it.
Jack
