87 stock fuel injector replacements
  • Thread starter Thread starter vinnie87
V
vinnie87
New to this forum, so Hi all... Have stock 87 and looking to replace injectors, does anyone know the lbs. of the stock injectors? and have read that the Ford Motorsports 19lbs are as close to GM stock at a more reasonable cost.. Does anyone have an info on this? thanks
Stock is 22lb/hr in 87.
24 was for the 85 model, probably the LT1 model too but i'm not sure for them.
That said, you should get the Ford SVO #24 and an adjustable pressure regulator. Its a direct fit replacement and the ECM can adjust the extra fuel. However, it may still run on the rich side since its rated at a different psi than the stock injector, so you use the AFPR to turn the pressure down a little to HELP the ECM adjust, and youre golden.
