'87 water leaks
Richard454
Atlanta,GA
87coupe,(2) 65 convert & 71 LS-5 ,M-21 convert
I need some help. I don't really know where to start on this water leak. I've removed the plastic drain covers at the base of the windshield - cleaned out just a little bit of debris- and I thought everything seemed to be in order.
I sprayed in the drains- and they seem to flow/drain the water just find- no water comes in unless I really aim the hose under the windshield w/ full flow.
This afternoon, after drying up all the water on the front floorboards- it rains again- more water on the floor. It's coming in on BOTH sides- running down the front of the floorboards- it looks like the water flows off the windshield, into the drain and then getting in the car. But I can't find w/o taking more apart. It just started a week ago.
Any ideas- problem areas to look for?
Thanks-
Hi. Welcome to the CAC! I would recommend sitting in the car the next time it rains to see if you can actually see the water coming in. Good luck!
Jay
