88-90 17" rim offset front to back?
Mad-Mic
Gone but not forgotten
Annapolis Maryland
1987 Redskin Red Coupe
or are they just right side and left side? i am curious cause i'm getting 2 goodyear F1 tires and moving 1 GSC to the back for now. in a month or so i will get the other 2 F1's.
can i just pull the front left and put it in the rear left? or should i dismount it and remount it?
I know the later stock wheels are wider in the rear. Mine are 9.5 rear, 8.5 front. If you've got the same tires all around, though, you should be able to rotate front to back - people with 9.5" wheels all around (ie, Z51 package) can do that.
[RICHR]
No problem.
The skinner front wheels didn't start until 1993. So, 88-90 wheels are the same size front to rear. They are different for right and left however.
The offset for these wheels should be 56mm if memory serves - I have the info at the office, not at home. Early C4's have 32-38mm offset. Fitting late C4 wheels on early C4's requires an adapter to space them out properly. Check out the Mid America catalog for information about this adapter in their wheel section.
