hexcarnut1
New member
- Joined
- Jul 23, 2010
- Messages
- 2
- Location
- Lindsborg, Kansas USA
- Corvette
- 1989 white convertible w/black top
:ugh This is my first Corvette and may be my last. !989 Conv. 52000 mi. auto. w/all the power goodies. I had to rebuild the drivers door due to some Klutz trying to pry it open with a crowbar. Busted up all the plastic. Then the headlights failed and I went through the rebuild process. Had it tuned and new ign, wires, 8.5 mm, new ign. module and all the rest of the normal service things done. Oh yes, I put in PULSEPLUGS. Now to the problem, It starts first time every time but shut it off and it will not start. Turns over fast enough but will not fire. Got spark and fuel press. The second time comes at either one minute of running or over an houe so I don't think that it is a heat problem. Got the best mech. arround here ad he is stumped. We are down to the ECM at this point but cannot prove it... ANYONE ? ? ?
Well believe it or not the problem turnedout to be 3 1/2 bad Injectors. The 1/2 was intermittent. Things I found out: The NOID light HAS to be bright or the injector is suspect, when OHMINg out the injectors the reading has to be within 15.8 to 16.9 ohms, mine ranged from 2.6 to 16.9, The car ran with all the bad injectors unplugged, not well but it ran. This only took about three weeks to figure out.
