I did the checks. I check the ecm. It checked out to be bad but when I unplug it the same wire had 12 volts even with it unplug
Sent from my SAMSUNG-SM-G870A using Tapatalk
Heres a list of things that you can check...
1. is the fuel pump running 2 seconds when the key is turned to ON ?
2. the fuel pressure IS around 40+ psi when the rails charge ?
3. the dist is wired correctly on the cap ?
The VATS is still active and working??????????????????????????????????????????????????
VATS has TWO stages of protection. most people only know about the starter enable and by-pass that thinking they have defeated the VATS....NOT TRUE.
The 2nd part of VATS is the injector enable. if VATS is pissed off, it will not allow the injectors to cycle during start up or any other time.
The way it should work......turn the key, the starter rotates the engine and if VATS is happy, it lets the injectors cycle as it gets a signal from the dist telling it that the engine is trying to run. The ECM will let the inj work when cranking if VATS is OK. NOT the pump.
Thats why the fuel pump shuts off after 2 seconds....to prevent flooding until the engine fires, then you get the pump again and injectors.
IF you have fuel pressure, 40 psi or more, and spark, I highly suspect that your injectors are NOT operating. Get a NOID lite to test the inj to see if they are firing. its hard to tell with a test lite....the noid lite tells you for sure. IF you have no injs cycling during cranking, go to the VATS module and start looking at that....key, key cylinder, module or relay. ALL the parts are available on E-Bay new. BUT you better learn about VATS or you'll be very lost....
Good luck !
