95pologreen
I am new to the forums, and was hoping someone could help me trace down an odd problem with my corvette. When I started up the car a couple of days ago the antilock light came on and the electronic climate control was dead. I also discovered that when I turn on the headlight the door chime, chimes all the time, even with the engine on and both doors closed. One last thing I noticed the courtesy lights are staying on for about 10 sec. when they would normally go off right after the key was on and the doors were closed. All of these problems happened all at the same time. I have checked all of the fuses, the abs system with a abs scanner it is showing no codes. Anyone have any ideas?
