topless82vette
- Joined
- Nov 1, 2001
- Messages
- 910
- Location
- southern california
- Corvette
- 1982 convertible (not factory) stock 350cfi auto
heres what I did to make mine fit although the clearance between the left upper a-arm is still tight it does clear ... first I took the upper radiator rubber mounts out of the brackets and turned them around, this moved the top of the radiator closer to the radiator support by about 1 inch also did the same to the bottom ones, then I cut the sides of the shroud down by a 1/4 inch and the inner air passages by 1 1/2 inches, then installed the shroud upside down, now all thats left is to make some mounting brackets and get the thing so it seals good and I should be in business, my car does have a C-4 radiator and the core is thinner than a brass one so this may be why mine clears the a-arm
