Help! '90 C4 Just replaced outer window/door seal
  • Thread starter Thread starter jmller
J
jmller
Replacement went fine, door panel reinstalled without major issues, but now when the window is rolled down it folds the inner seal down into the door. Anyone have any advice ?
Confused !
#1. Is the door panel installed properly?
#2. Did you replace and/or adjust the anti-rattle pads? If I remember correctly, there are two felt/rubber pads inside each door, adjustable on top. The outer window seal pushes on the outside glass surface. The anti-rattle pads push on the inside surface of the glass surface. Wiggle the window, does it feel sloppy?
