90 zr1
thor25
New member
mo
90 zr1
Hello,Need some help on injector problem.The secondarys are not working again,It was in shop 2 years ago for this problem,the installed a reman computor and it worked for a while.There are no codes,no blown fuses,no vacume leaks,where do i go from there? Has anyone else had this problem? Thanks Thor
Make sure the connections to the cpu are good. Maybe slide each wire out of the connector and clean the contact. I did that on an 82 with intermittent cpu problems and that cured the problem.
Do you have a Factory Service Manual?
I dont have a service manual, I am looking for one. Thanks Thor
