atmmac
Just called my chevy dealer about my heating/ac problem. I wanted to get everything all set for putting the car away for the winter so that next summer pull the cover off and all set. My heater and ac wasnt blowing out fast at all. and my parking brake like a lot of them around was not working correctly so i brought it in. I figured around 300 bucks tops to fix. I get a call the parking brake will be 200 to fix because they have to pull off the rear brakes. Then i learn there was a mouse nest at one point in the heating box. My uncle told me that it had happened before when he had the car stored for 2 years. Hence the 11,000 miles. Anyways it turn out the problem is below the battery with a split vacuum line. He said they will pretty much have to pull off my fender. Ringing up the GRAND TOTAL OF 900 DOLLARS!
