91 Parts for sale most new some used
ddahlgren
Mystic CT
91 Dark Green Coupe
C4 parts all new unless otherwise noted
New
DRM Camber brackets 100.00 + shipping
DRM Trailing arm brackets 100.00 + shipping
VBP 32 mm front sway bar with poly bushings 125.00 + shipping
VBP 26 mm rear sway bar with poly bushings 125.00 + shipping
HD Camber rods with 3/4 heim joints and seals it boots 150.00 + shipping
Bushings need to be fabricated for spindle side attachment.
Pics available soon.
HD Trailing arm links with 3/4 heim joints and seals it boots 250.00 + shipping
Passenger side door weather stripping NOS GM 10269866 79.00 + shipping
91 and may fit others E-brake cables GM 19143753 20 each + shipping
GM 14076924 teflon thrust washers for rear axle shaft 10 bucks for the pair plus shipping
4 NAPA u-joints 231C coated to prevent corrosion made by Federal Mongul in the USA
30.00 ea + shipping
2 NAPA U-Joints #280 Super strength for drive shaft made by Federal Mongul in the USA
20.00 each + shipping
Nitrous works fuel and nitrous solenoids #19002 and #19003 old stock the package is pretty tired looking but new never opened never used in any way. They were at the track spares for a car I raced about 5 years ago. 100.00 for the pair plus shipping
91 Reproduction radio DIC bezel made in China I have no idea what it is worth 10 bucks plus shipping? Or will toss it in with any order over 150 bucks..
Used stuff
91 Bose radio head w/cd and cassette needs repair will not accept a cd I don't own a cassette anything so no idea there and radio operation unknown as car had a defective antenna. It would make a good core to have redone without pulling your car apart while waiting for repair. 150.00 + shipping
91 Bose radio unit used condition unknown a rebuildable core and possibly fine as is. 75.00 + shipping
Bose speaker amps used some should work, I bought them as used tested some might not and have no idea which are which as the whole update the radio / cd player was a long confusing deal and finally quit trying to figure it out and replaced it all I also have a bunch of Bose speakers I have no way to test any of it and suspect packaging time is longer than what some of it might be more work than they are worth. 200.00 + shipping for all of it or make an offer if you want some of it.
91 used antenna bad mast but have a new replacement. Motor works fine but was missing the bezel nut so ended up buying a complete antenna new from GM 50.00 + shipping
