D
DawgOn
I have a new Golen stroker with 58mm BBS throttle body installed and I am questioning whether or not I can or need to adjust the TPS, as it does not seem to be adjustable.
I am getting 4.88 volts from the "A" to the "B" TPS connection leads, which is out in left field relative to the .54 volt TPS setting spec. for other model years. Is the '92 TPS adjustable? If so, what is the procedure? :confused
